L35 5.7L vortec motor? worht building?
hey guys the 5.7L (350c.i.) vortec motor is the easiest of easy and one of the cheaper swaps into my truck with little alteration of anything-
i was wondering- grabbing a 99 or 2000 5.7L vortec and doing the following would allow for 600 to 700whp
4-bolt mains w/ ARP studs
Eagle rods
JE 8.5:1 CR boost pistons
Total seal rings
Clevite bearings
balanced/blueprinted
ARP rod bolts
ARP studs on the cylinder heads
lots of cylinder head work
mild to big boost cam
S78 turbo
full built 4l65e
would that set-up be good for those power goals-
Eagle rods
Total seal rings
Clevite bearings
ARP rod bolts
S78 turbo
full built 4l65e
you can build that engine to make that power amount easily, not sure about the induction you would use. i think those injectors only feed about 350-400 rwhp if that. i think that motor hog pointed out has a little bit to high of compression for what you wanna do....
Nimoryan
07-05-2015 04:50 PM
