L92 on 5.3?
Old 01-11-2010, 08:27 PM
norris_83's Avatar
Default L92 on 5.3?
I've read on a couple of forums of ppl installing the L92s on 5.3s... everytime i ask how is it done, they don't know.... is it actually possible??? And if not, is there any proof??
Old 01-11-2010, 08:29 PM
LS1TRUCKGUY's Avatar
the L92's are made for the larger bore... 4" i believe...
Old 01-11-2010, 08:42 PM
Wearin' da big hat
00ChevyScott's Avatar
Originally Posted by ls1truckguy
the l92's are made for the larger bore... 4" i believe...
x2...
Old 01-12-2010, 12:49 AM
Banned
lucky77's Avatar
if your reffering to l92 heads/ on a 5.3(327) ur answer is "NO" 5.3's have a bore of 3.7X and (l92/l76/ls3 heads) require a 4.0 BORE, meaning that you need at least a 6.0 engine to run those heads . And a 5.3 block could SAFELY only be bored out to 3.8X . .in addition those heads have square intake ports.
Old 01-12-2010, 01:25 AM
SLO TRUCK's Avatar
Actually 5.3's are bored out to 3.905 all the time
Old 01-12-2010, 01:45 AM
Banned
lucky77's Avatar
yes 3.905 to make a 383 , but than again ur walls are going to be really thin, ur gonna have run a good water pump+radiator to clear cooling issues..
Old 01-12-2010, 07:48 AM
Resident Retard
BlackGMC's Avatar
I thought boring a 5.3 to 3.905 would make it a 346, adding a long stroke crank would make it a 383
Old 01-12-2010, 07:58 AM
9 Second Truck Club
stock48's Avatar
It could probably be done if you notched the bore, and moved the cyl head with offset dowls but I wouldn't run that large of a runner on a 325Ci engine.
Old 01-12-2010, 01:18 PM
corvette_uae1's Avatar
im puting one in my 5.3 ill get u pics for my setup this weak
Old 01-12-2010, 01:31 PM
Baltimore Whore
Mangled03gmc's Avatar
Your putting a L92 in your 5.3's place?? The 92's heads as stated need that 4.0 bore to work..
Quick Reply: L92 on 5.3?
