L92 head milling
L92 head milling
After searching all day, i'm still unsure of a few things regarding a potential L92 head swap onto a LQ9.
My only issue is the loss of compression, and wonder if milling is an option to get back to optimal compression, around 11:1 ish, with a stock bore, flat top.
How much milling, gasket thinkness would be required for this..sorry if this has been asked before, i just couldnt find the info myself.
TY
TY
Found this old thread on tech with some interesting info about L92 swaps
https://ls1tech.com/forums/showthrea...hlight=slp+l92
We also use the correct/different spring seats and new valve seals to make 1.800 install height. Using the stock L92 spring seats with valve seals (one piece) will give a compressed install height (unless you mill down the head under each spring seat). We are not just slapping springs and retainers on these heads, that does not work.
i dont know why he would say it if it wasnt true, unless he missed something. maybe have to have new spring seats installed.
look for C6R Motorsports on Ebay, they offer a package as well for around the same price.
spent the last 1/2 hour reading and it might help if they come in a little shy, 1.78. and even gm springs dont exactly measure that much. I just need to check them when they go together.
I get lost reading on tech
GrooveCityZ71
08-31-2015 12:05 PM
lxcoupe
08-26-2015 07:24 PM
BennyB
08-01-2015 08:48 AM
