L92 setup for a LQ4
Old 01-19-2007, 06:09 AM
  #21
jasond26's Avatar
I have also jumped on the l92 band wagon. I ordered my set from TSP and hopefully I will have them by middle of next month. I will be using a Becks intake though. It should rock
Old 01-19-2007, 09:03 AM
  #22
SS_bnoon_SS's Avatar
Originally Posted by Richard@WCCH
As far as valves sizes are concerned, our valve vendors are making intake valves 2.160" and 2.180" with the proper length.
Richard, are the valve lengths different from the LSx gen III engines?
Old 01-19-2007, 03:21 PM
  #23
FormerVendor
Richard@WCCH's Avatar
The factory stock L92 valves are the same length as the 6.0l and LS1/LS6 engine family. Our aftermarket valves will probably be a bit longer to accommodate the higher lift cams. I don't have an exact length worked out just yet, but it will probably be in the +.100" area. We're definitely going to have a longer tip length on these valves to reduce the possibility of rocker arm/retainer contact.
Hope this helps.
Richard
Old 01-26-2007, 10:30 AM
  #24
KB
13 Second Truck Club
KB's Avatar
Other than the corresponding Intake manifold, is there anything else you would need to utilize the L92 heads on a stock LQ4 shortblock?
Old 01-26-2007, 10:43 AM
  #25
04BlackSilverado's Avatar
A stock L92 gasket or an aftermarket 4.06" Gasket
Thats it....
Old 01-27-2007, 10:45 PM
  #26
Black02Z71's Avatar
check out this trailblazer SS with L92 heads, and L92 truck intake
https://ls1tech.com/forums/showthread.php?t=647662
442 RWHP
Very impressive, I'm so going L92
Old 01-29-2007, 11:49 PM
  #27
Originally Posted by Black02Z71
From what I've been reading the L76 is used in the Holdens cars, as well as the new Vortec Max silverado, is indeed a 6.0L.
http://media.gm.com/us/powertrain/en...New/07_L76.doc
http://media.gm.com/us/powertrain/en...lanche_SAE.pdf
366 hp and 380 torque 6.0 L76 to 345 hp & 375 Torque Lq9 - It is a 21 hp increase and 5 lbs of torque - $ 1000 - is it worth it? I wonder if the heads are making this or the intake?
Old 01-31-2007, 04:13 PM
  #28
Originally Posted by 00Z71
366 hp and 380 torque 6.0 L76 to 345 hp & 375 Torque Lq9 - is it worth it? I wonder if the heads are making this or the intake?
Well consider how much better they would respond to a cam and headers.......
Old 01-31-2007, 04:47 PM
  #29
True, but it is a lot of work
Old 02-01-2007, 10:48 AM
  #30
Yeah, but the numbers will show its worth it........
I'll let you know in a month or so.
Quick Reply: L92 setup for a LQ4
