L92 Springs LS7 cam
L92 Springs LS7 cam
I am looking into getting a LS7 cam for my 5.3 silverado, and a set of L92 springs also. My questions is will the cam and the springs fit on my truck?
The specs for the cam are:
Camshaft Duration:
211 degree intake / 230 degree exhaust
Camshaft lift (in):
.591" (15 mm) Intake and Exhaust
I am not that good with this part of motor work but i am trying to learn i have some info that i have recived from some members. so is that a good cam spec.
Camshaft Duration:
Camshaft lift (in):
Terrible cam in my opinion for a 5.3L n/a truck. Not to mention you have a gen III motor and the ls7 is a gen IV motor. The cam position sensor among other things will be an issue. You will be much much better off getting a custom grind or at the very least get an 01-03 ls6 cam.
