let me raddle your brain on this... plz help
Old 09-28-2007, 12:07 PM
whitesilvy04's Avatar
Originally Posted by PappyDan
Lets see where your going with this.
your 4.8 head has a 61.15 cc chamber and 1.89/ 1.55 valves
with a piston size of 3,779 with a stroke of 3,270 to give you
A compression of 9.49.
your 243 ls1 heads come with a 66.67 cc chamber and 2.00/ 1.55 valves
to work with a piston size of 3,893 with a stroke of 3,622 to give it
A compression of 10.19.
now the 243 heads will flow better but you increased your
chamber size on a smaller piston and a smaller stroke
That will drop your compression down close to a 9.0 or even a 8.9.
their is no cam on this world that will make up the lost power
From the lower compression on your 4.8.
Now a turbo or a supercharger would love this kind of low compression.
the best way to go is to shave 0.20 or 0.30 off of your 4.8 heads to up
Compression from 9.49 to a close 10.0.
Then add your cam for more power.
Thanks for taking the time and helping me understand it better Pappydan
Old 09-28-2007, 12:21 PM
TXsilverado's Avatar
wait....pappy made a mistake in his math. the chambers on 243 heads are 64.45cc not 66.67. 66.67 is the compression of a stock LS1 head. the compression will still be lower but not as bad as pappys math shows using the wrong chamber size.
Old 09-28-2007, 12:35 PM
Tribe Shaman
PappyDan's Avatar
damn it, well i was not too far off from the top of my head.
243 is LS6 not LS1 guess i need to read that book again.
thanks stew for the correction.
Old 09-28-2007, 12:38 PM
could you look up what size chambers your book says the 243 head is. i think 64.45 is a rough estimate floating around the net.
Old 09-28-2007, 12:43 PM
Tribe Shaman
PappyDan's Avatar
LS6 01-04 243 cast in/ex port 210/75 cc chamber size + gasket is 64.45 cc
from the book.
Old 09-28-2007, 01:59 PM
ap2002's Avatar
damn yall got my brain fried with all those numbers!! I dont understand **** about cc and stuff...
Old 09-28-2007, 03:48 PM
so what would the compression be then with the correction?
Old 09-28-2007, 04:33 PM
Tribe Shaman
PappyDan's Avatar
shaved down 0.30 will have it close to normal
Go5.3tt06
25
09-04-2016 10:25 AM
Mr. Chainsaw
10-18-2015 08:00 PM
InsaneDomestics
07-27-2015 02:42 PM
sleepersilverado
04-04-2003 03:04 AM
Quick Reply: let me raddle your brain on this... plz help
