lifter retainers
Custm2500's Rude Friend
You can re-use them if there in good shape but there so cheap why not change them... for the LS1 style I think I got all 4 for less then $20 From SDPC. One of our sponsers
They are different for different motors.
#12551162 -Lifter Guide, LS1/LS6 4.8,5.3,6.0 truck engines
#12595365 -Lifter Guide, LS2/LS7
#12571596 -L92 Front Lifter Guide
#12571608 -L92 Rear Lifter Guide
I believe the L92 is also the LS3 style but not 100% on that. Maybe some one else can Clear that up
I do know you can use the LS2 style in th LS1 style engine but not the other way around. The LS2 style is supposedly stronger....
i always reuse them... i would upgrade to TI retainers if you are planning on revving to 6500+ though.
i run a dual spring with TI hats now![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
edit, just re-read the title. LIFTER retainers. i am a moron. the end.
i re-use those too though. did a h/c/lifter swap a few weeks ago and just went back with the same ones.
