Link Dead, Please Fixy
Hey, does anybody know the ICL of the Vinci Trucker cam? The LSA is 115, and I'm *assuming* that the cam has 4* of advance ground in, which would make the ICL 111*, but I don't know for sure...
Here's what I came up with
364 cid
10.5:1 compression
303 cfm@551 intake lift
278 advertised duration - 216 duration@.050
.551 valve lift
111 ICL
4700 lbs.
501 HP
396 RWHP
Shift RPM 6163 (I was thinking 6200...pretty darn close)
Max RPM 9038
1/4 mile ET: 13.44
When I hit submit, a window popped up that stated "The heads you have selected may be large for your cam compression numbers". I tried the calculator at 11:1 cr and 12:1 cr and got the same message. Maybe I'll try some different lifts just for kicks.
I was actually concerned about my WCCH stageII 317's outflowing my cam choice, but Richard at WCCH assured me that I'd be fine, and I'll take his word over the online calculator. I noticed on WCCH's website that the StageII 317's flow the best between .550-.575 valve lift, and my cam has .551 lift, so I'm thinking that it's a good match![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
This calculator is pretty cool...
*EDIT* Lowering the head flow CFM down to 267 made that pop up window go away...
364 cid
10.5:1 compression
.551 valve lift
111 ICL
4700 lbs.
501 HP
396 RWHP
Max RPM 9038
1/4 mile ET: 13.44
The way I spec a cam is to find the best lift on the head (say .575) and then make the cam lift slightly more than that (say .585). That way, for each cam revolution, you are hitting max flow twice, and generally speaking, max flow on a head isn't a cliff-like dropoff, so you get max flow - great flow - max flow as the cam goes to max lift, and then begins to fall again.
I'd listen to Richard over any online calculator AND over me!
PT's Slowest Truck
Yea, I take Richard's word as the gospel...I am curious how the 232.4cc intake runners will affect my bottom end torque though. I know that bigger ports slow air velocity down and move peak torque up, so hopefully it won't be too bad. I have a cam that should be torquey in an LQ9 (216/224 .551/.551 115), and planning a 2600 converter...I hope that my big intake runners aren't going to be too mis-matched with the rest of the set up.
Sorry to get the thread too far off track...
