long rod 6L.........anyone done one here?
https://ls1tech.com/forums/showthread.php?t=524413
Originally Posted by stang90gt50
I have all the parts to put together a little different shortblock and I think I like the idea of putting the longest rod I can in the motor without going to far...
I have a stock 3.622" crank, standard 6.0L block, 6.300" Eagle H-beam Rods, Mahle 4.00" (402" stroker shelf pistons) forged pistons...
This would be a standard 6.0" but have a longer rod and would probably work better for the high rpm boost motor project...
Any impressions of the long rod setup?
I AM A MOTHERF*CKER
Not if you use a stroker piston with a higher wrist pin placement. They numbers they show in the other thread indicate that this mod will actually drop CR (they did the math and show that the piston deck height will be 0.010 while stock piston deck height on these blocks is -0.008).
Looks like a good idea on paper anyway. I'm not sure I'd want to be the first guinea pig
murderedSS
27
10-12-2015 11:13 AM
