looking for a cam
Old 01-20-2009, 03:02 PM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by 50adrod
why did it only last a month?
I'm assuming that he meant that the "feeling" only lasted a month until he got used to it and wanted more...
Old 01-20-2009, 11:49 PM
Luke03's Avatar
You can do the TR224 also! Same cam im about to get.
Heres a clip of a buddy of mines truck with a TR224 (with 114lsa) and Pacesetter Lts/ORY through corsa exhaust
http://s18.photobucket.com/albums/b1...t=MOV00354.flv
But if you aren't going to get a converter I wouldn't recommend this cam
Old 01-21-2009, 07:17 AM
nlawson6.0's Avatar
i just didnt like the cam at all (But it did sound okay). I switched to the cam in my sig and it actually felt alot better!!
Old 01-21-2009, 11:16 PM
1quickRST's Avatar
You should call comp cams, that's what I did and I love my cam! Tell them what you got and what you are trying to achieve. I am positive they will have what you want.
Old 01-21-2009, 11:51 PM
9 Second Truck Club
stock48's Avatar
A short duration tight lobe center cam will give you that old school chopy idle. A cam with duration in the 218* @.050'' range on a 108* will give you a good chop and not need to rev 6500000RPM to make good power.
Old 01-21-2009, 11:56 PM
blackbeast ss's Avatar
heres a clip of a TSP 228R cam
http://videos.streetfire.net/video/C...-SS_208615.htm
Old 01-24-2009, 01:01 PM
SynergyV8's Avatar
Comp Cams XR259. Brute low end, strong mid range and it'll pull all the way to 6000 in the 5.3L. If you want it to buck, chop and lope around at idle, lower the target idle speed with the tune. Don't pick a camshaft solely based on the sound it will make; find a cam to optimize the setup and play with the exhaust routing and mufflers to get the sound you're after instead. Picking a cam for sound is like bringing home a stripper from the club and expecting marriage material.
2500ZL1
01-25-2016 06:30 AM
lawhitediamante
08-12-2015 12:14 PM
steves86ta
07-28-2015 10:21 AM
WICK3DxGATA
07-21-2015 06:59 PM
projectnightcrawler
07-19-2015 11:30 PM
Quick Reply: looking for a cam
