looking for a cam
You can do the TR224 also! Same cam im about to get.
Heres a clip of a buddy of mines truck with a TR224 (with 114lsa) and Pacesetter Lts/ORY through corsa exhaust
http://s18.photobucket.com/albums/b1...t=MOV00354.flv
But if you aren't going to get a converter I wouldn't recommend this cam
Comp Cams XR259. Brute low end, strong mid range and it'll pull all the way to 6000 in the 5.3L. If you want it to buck, chop and lope around at idle, lower the target idle speed with the tune. Don't pick a camshaft solely based on the sound it will make; find a cam to optimize the setup and play with the exhaust routing and mufflers to get the sound you're after instead. Picking a cam for sound is like bringing home a stripper from the club and expecting marriage material.
