Looking for some input lq9 408 ?
Old 08-19-2012, 04:53 PM
silverado.408's Avatar
Default Looking for some input lq9 408 ?
Well i have a 408 build in the process all motor no boost. I have a cam in mind just not sure how it will work out for a dd/ friday night roll racing. Need some help with rear end choice and just anything in regards to the cam. Do it dont do it and reasons why. Thanks Cam is Comp cam LSR 251 267 115lsa .624 .624
Old 08-19-2012, 04:57 PM
AndysC3's Avatar
That's a healthy cam for a 408. What trans and torque converter are you going to be using?
Old 08-19-2012, 05:13 PM
I was planning yank ss4000 HEHE and built 4l60e but a 4l80e is looking for better choice.
Old 08-19-2012, 05:17 PM
Just for info Build is ported l92 manley valves, terra 1.7 rockers, fast 102rt, 1 7/8 lts, bolt ons and new muffler bearings. Looking for 11.0.1 compression pump 92
Old 08-19-2012, 06:31 PM
oakley6575's Avatar
I would commit suicide if I had to drive that cam around daily. Do you have any experience with cams that size? You would probably have to spin that thing to 7500 to make peak power! haha
Who ported your heads?
Old 08-19-2012, 06:40 PM
A shop here in tacoma wa. I have a 235 243 111 in a solid motor mount 2000 z28. Thats real fun to drive lol
Old 08-19-2012, 06:44 PM
So why not that cam ?
Old 08-19-2012, 06:57 PM
AndysC3's Avatar
I cam in the upper 230s would be more DDable. and a 4K stall TC will be fun to dd.
Old 08-19-2012, 06:59 PM
milkey57's Avatar
Well the usable range of power on that would be 3500-7k rpm so in a 5000 lb truck you might as well get out and push it from a stop. You would need retarded big gears and that 4k stall wont do a thing. A 227/235 lsl cam on a 113+4 would be a lot more fun and drivable.
Old 08-19-2012, 07:22 PM
skeet's Avatar
theres nothing wrong with that cam and stall being streetable,is it optimal probably not just depends on what you like, i run a 25x/26x on a 621 113+2 i drove my RACE truck many have called it every where i have almost 3k miles on it and she runs strong,i detune it for gas mileage, you get a good no not good a great tuner then youll have NO issues!!, now if youre gonna keep it NA with a little juice and you want all out power try some 4:56 gears i ran 4:88s and my truck was and is a monster on the street, torque comes in just over 4k hence the stall i have yet to put it on a dyno but i plan to soon, the rearend i run is still a 10 bolt though i went down to a 4:10 gear for the nitrous shot i plan to run, i wish i would have kept 4:88s in i just loved them, it hit hard and i was close to where i was wanting to be cutting mid to high 1:40s 60s and trapping 120s+on motor, now that i made changes to compensate for the big shot i lost some mph and 60 ft times.
i also run a 4l60e behind it shes been 10.4 at a 132 on 150 shot with little spin off the line, only thing i can say is stiffen that rearend as in a good 4 link or ladder bar set up, if you have to much flex in the pinion it wont last long! by the way that SS4k will flash its *** off in a truck, the only issues youll have is better make your rolls around 40-50 mph lol im breaking loose right at a 60 punch.
do as you please but it sounds like you want it all, so id listen to the ones that have ran such a setup on the street!!!
7500 rpms aint **** for a LS motor, ive done it numerous times on a stock lq9 shortblock!!
rpms is horsepower!!!
Quick Reply: Looking for some input lq9 408 ?
