Loud choppy cam for my 5.3
Old 06-30-2009, 06:35 AM
makes children cry
_zebra's Avatar
have you seen these?
http://www.compperformancegroupstore...GEN3CAMSThumpr
Originally Posted by AdioSS
just pull a plug wire...
Old 06-30-2009, 08:41 AM
04Crew's Avatar
OP - there a hundreds of cams that will give you a loud choppy idle. You could go with anything from a low 220's cam on a very tight LSA to 230+ if you want to. You need to provide more info about other preferences.
Do you have a desired rpm range?
Do you run a stall?
What is your max desired lift?
Do you mind the sewing machine sound that can sometimes be associated with high lift?
Do you want to run double springs?
Old 06-30-2009, 10:36 PM
trenz68's Avatar
i will be running a 3400 stall, 918 springs. looking maybe a 109 or 110 lsa. Dont want a lift that is gonna hurt the engine either.
ChucktheBarber (06-17-2019)
Old 07-04-2009, 04:18 AM
ap2002's Avatar
for the chopiness, i have always like a cam that MTI used to spec out, it was a reverse split, 230/227 .57x/.57x 111lsa, it chopped real good on a 6.0 so it should lope a whole lot better on a 5.3
Old 07-04-2009, 05:10 AM
12 Second Club
AdioSS's Avatar
Take a look at what Comp did with their Thumper cams compared to others. A lot longer exhaust duration than intake, tighter LSA and more advance ground in.
Old 07-04-2009, 05:37 AM
trenz68's Avatar
Ya rhey have some good specs. Do u have one in mind?
Old 07-04-2009, 08:53 AM
PT's Slowest Truck
budhayes3's Avatar
I'm having a problem finding the specs for those Thumpr cams on Comp's site...if someone could provide a link to the specs that would be cool.
If you're just looking for a choppy, lopey sounding cam, you want a lot of overlap, so long intake duration and a tight LSA is in order. The lobe design and valve events also take a role in this sound. Many of today's cams have agressive ramp rates that actually provide more performance with less lope. Set the engine idle as low as possible without stalling and that will help. If you're looking for an inexpensive alternative, the GM Hot Cam is mean sounding and is kind to the valvetrain with it's low lift of .525/.525 and less agressive lobes. It's available as a kit with springs also. The rest of the specs are 219/228 112. It's not as good of a performer as the newer grinds out there available in the aftermarket, but all of the clips that I've heard of it sound cool...you can probably hear it on Youtube. I've often dreamed of having enough cash to finish my LQ9 project and keeping my 5.3 for an old hot rod (say a 31 Ford 5 window coupe with a 32 grille, fenderless, satin black...just a quick thought lol), and just getting a hot cam for it, and the newest addition would be the new Edelbrock intake with it's tunnel ram styling
Old 07-04-2009, 11:39 AM
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
here you go the specs on the thumper cams smallest to biggest with the part numbers looks like there all cut on a 109 lsa
THUMPR™-High performance street,stock converter ok, best with 2000+converter & gears, choppy and
thumping idle.
2000 to 6400
54-600-11
275THR9
275 295
219 233
.553 .536
109
*****’ THUMPR™-High performance street/strip, needs 9:1 CR, 2500+ stall, intake, gears, and headers, rough idle.
2300 to 6600
54-601-11
283THR9
283 303
227 241
.563 .546
109°
BIG *****’ THUMPR™ - Street/strip, needs 9.5:1 CR, 2800+ stall, intake, gears, & headers, very rough idle.
2600 to 6800
54-602-11
291THR9
291 311
235 249
.573 .558
109°
Old 07-04-2009, 11:44 AM
trenz68's Avatar
ya im thinking the first one. 219/233 .553 .536 109lsa
Old 07-04-2009, 12:14 PM
PT's Slowest Truck
budhayes3's Avatar
Yea, me too, especially for a 5.3. with almost 220 intake duration and the tight 109 LSA that's a bunch of overlap as it is. It will still sound mean and have a more useable RPM range with better low end torque than the other 2. I've noticed that Comp has always been quite liberal when listing their cams' powerbands and where the power starts...Thanks for posting the specs twolow02fransen.
I'm assuming that Comp has ground in so much exhaust duration to help evacuate the exhaust gasses since there will be a lot of exhaust revision into the intake with the tight LSA and the intake and exhaust valve being open at the same time so long.
Quick Reply: Loud choppy cam for my 5.3
