LQ4+243 milled to .030- Whats your thoughts?
Old 05-09-2012, 08:49 PM
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
Originally Posted by brandon6.0
Whats a good safe PTV reading/setting?
So with .030 milled i would need only .051 gaskets for around 11.0 compression?
And
.020 milled with .040 gaskets for around the same ratio?
I'm running the stock MLS .051 gaskets I'm guessing MPFD is running cometics all i know is AI told me id be right at 10.8 to 10.9 with the stock gaskets and my 243 heads milled .030 so they went from 64cc to 60cc
Old 05-09-2012, 09:50 PM
brandon6.0's Avatar
ok gotcha! Cant wait!
Old 05-09-2012, 09:55 PM
11 Second Truck Club
MPFD's Avatar
The chamber for all intents and purposes is a dome. Each .010" you mill off changes the cc of the dome slightly less then the last cause the diameter decreases with each pass. By taking it out at the gasket you get a bit more diameter this gives you a bit smaller over all chamber then taking it all off the head... Minimum PTV clearance should be .080" on intake and .100" exhaust, but I'd rather see more...
Old 05-09-2012, 11:26 PM
2doorfury's Avatar
im doin about the same build. i have 243's milled.020 on a lq4..what head gaskets are you guys running?? ls1 to match the heads or 6.0??
Old 05-10-2012, 08:39 AM
6.0 gaskets the ls1 gaskets don't have a big enough bore you need them to be for a 4 inch bore or larger
Old 05-10-2012, 08:49 AM
MPFD's Avatar
I used cometic's, but they are high $! On my new motor I want more volume so I'm gonna run LS9's.
Old 05-10-2012, 10:43 PM
Stampede4ever's Avatar
Does anyone know how much HP/TQ you guys are putting down?
Thanks.
Old 05-10-2012, 11:12 PM
MPFD's Avatar
Well my set up wasn't a dyno queen. It's first numbers were 330hp/487ft-lbs. with the patriot cam. But if you put its weight & 1/4 mile times in any HP calculator it figured to be 413hp +/- 5 depending on which one you use. The BRE cam made a huge difference in power but it never got to the track. I'm pretty confident it would have gone at least high 12's NA...
Old 05-11-2012, 08:14 AM
brandon6.0's Avatar
Yeah im shooting for high 12s on motor and try to spray her into the 10s. Should make for a pretty good weekend toy.
What length push rod u running with your heads milled that much and .040 gasket? I currently have 7.4s with .650 patriot gold springs. I know that will be to much push rod once i mill these heads and change gaskets.
Old 05-11-2012, 08:15 AM
MPFD's Avatar
You will just have to measure and see what it needs.
Quick Reply: LQ4+243 milled to .030- Whats your thoughts?
