LQ4 6.0 w/ Milled 243s
#31
wow that's a lot of information.
i've emailed Richard again, waiting on a reply. one day i'll end up buying a cam lmao.
Thanks.
what about this cam?
http://store.summitracing.com/partde...3&autoview=sku
Thanks.
#33
i decided to make a 370. i Think that's when you bore the motor .30 correct?
i'm going to stay with stock head gaskets/243s milled with patriot gold/pistons are unknown. should i pick up some new rods? im going with ARP head studs/rod bolts/i have 12 point stainless steel header bolts.
cam is still unknown because i have yet to get the heads milled since i've changed my mind about the compression. yet, to know the compression, i need to decide what pistons i will run. any input on the pistons?
i'm thinking of running an 11:1 compression now instead of a 10:5:1 compression.
i'm still piecing the parts together and such. so it's going to be a while.
i'm more than likely going to slap a 150 shot on it too since i'll be running a FLT Level 5 65E with a Vig3200
#34
i read on an LQ9 you bolt stock 243s on it and you'll have an 11:1 compression.
Is there a good piston(for Nitrous) that will give me the 11:1 compression i'm looking for? should i upgrade my Piston Rods too?
how much do i have to bore my 6.0 out to make a 370? is it possible to make a little bit bigger motor without stroking it out?
Help asap because i'm wanting to bore my motor and get this thing together within the next 3 months.
zblee
11-11-2015 12:41 AM
Tigger Welder
10-01-2015 08:41 AM
FormulaZR
09-14-2015 05:23 PM
