LQ4 BEST complete rotating assemblies?
Old 08-25-2010 | 12:14 PM
budhayes3's Avatar
PT's Slowest Truck
The only thing that I can think of is maybe no coolant flow around those cylinders causing the cylinders to heat up and seize the rings to the pistons. I'd think that if it was an oiling issue you'd lose a bearing before you'd weld the rings. The machine shop should have hot tanked the block which should have cleared the coolant passages. Does anybody know if it's possible to put a head gasket on incorrectly and block coolant flow? I know that was possible to do on certain V6 Toyotas and it would cause an overheating problem that was a bear to diagnose...
Old 08-25-2010 | 11:06 PM
Remember_54's Avatar
thank a lot, will check it, BTW which pistons tops is best for my engine which
use magnacharger on it-29cc or -16cc, or any other
one, please guys advice
Old 08-26-2010 | 01:56 PM
guys waiting for answer : what is the best for my engine pistons top, to use with
one
thanks in advance, i think 9:1 compression is good for charger
Old 08-26-2010 | 04:03 PM
z71gmc06's Avatar
I'm not an expert in this area but a quick search showed many threads like this one.
Try putting in search for "compression FI charger" or other such terms.
https://www.performancetrucks.net/fo...for+fi+charger
Raffman
07-23-2018 03:26 PM
Knightcrawler
07-20-2016 04:29 PM
SlvrSierra4.8
10-01-2015 10:39 PM
zraffz
09-08-2015 08:40 PM
USMCvet0311
09-04-2015 10:43 PM
