LS in a OBS, help me finish my top end!
#21
don't bother with the roller rockers . . . . the stock ones are plenty good.
The cam bolts . . . they're just plain jane cover bolts that hold it down. Tell them to send it !
Keep in mind, you're going to have to extend your cam gear sensor - yes it's easy
Get the LS2 timing cover . . . meaning more gold paint !
#22
On to the gold paint. I have a full can left. Originally I was going to paint the lines in valve covers gold, tape them off and spray black. The gold didn't completely dry off so when I removed the tape, some of the paint came off. So now the Valve covers are flat black. Once i get all the parts in doing another 4-5 coats on the timing cover, what paint is left will go back on the motor. I <3 black but it has no business being in the engine bay!
FYI what this all going into
Part: 12638427*
Category: Engine Camshaft
Description: CAMSHAFT
Min.Qty: 1
Unit Price: $97.93
Quantity: 1
Ext.Price: $97.93
Core Charge: $0.00
Part: 12586481*
Category: Engine Camshaft Sprocket
Description: SPROCKET
Min.Qty: 1
Unit Price: $14.62
Quantity: 1
Ext.Price: $14.62
Core Charge: $0.00
Part: PK12600325*
Category: Engine Front Cover
Description: FRONT COVER KIT
Min.Qty: 1
Unit Price: $123.60
Quantity: 1
Ext.Price: $123.60
Core Charge: $0.00
SUB TOTAL: $236.15
SHIPPING: $60.22
TAX: $0.00
TOTAL WITH TAXES: $ 296.37 * indicates special order item, which is a special
order non-returnable part.
#28
don't want to sound cheap but what about these
Texas Speed & Performance Chromemoly Pushrods
#29
Well I finally got the e-mail I have been waiting for...2 weeks from GMPARTSDirect.com that my LS9 Cam and Components are being shipped!
Here is just a list no part #'s (possible might grow-eek):
6.0/2wd 4L80e with harness, computer,& MAF out of a 00 Chevy 2500 Series P/U that has 111k on it
Complete Engine Gasket Kit with ARP Head Studs, Harmonic ARP Bolt, and OEM Thick MLS Head Gasket
New Melling Oil Pump
New Water Pump (06 Sierra b/c needed the waterneck a certain way)
New Cam Sensor
New LS2 Timing Chain
New Coolant Sensor
Reman Starter
Starter Heat Shield Wrap
A/C Delco Plugs
Schoenfeld Conversion Headers
Grade 8 Locking Header Bolts
Reman A/C Compressor
Motor Mount Conversion Plates
New PRC CNC'D L92 heads
Used L92 Intake with all the goodies on it
90mm Drive By Wire (DBW) Throttle Body
Used Crank Pulley
New Stock Electric Fans (New) from 06 Sierra
New HD Radiator (New) from 06 Sierra
New LS9 Cam, LS9 Sprocket, LS9 front timing cover and sensor
Pushrod Length Checker
New 7.400" Hardened Pushrods
New LS7 Lifters
New Comp Cams LS HD Rocker Arm Bearing Assemblies
New OEM L92 Rockers and Guide Plates
411 PCM
****Transmission****
New Transgo HD2 Shift kit
New Trucool 140k Transmission Cooler
New 2wd Actuator
New Tranny Filter and Gasket
******* Converter...not sure which one to go with.
If there is anything missing, feel free to let me know. Questions...please ask b/c I couldn't get this far with out asking them. Time to give back...
Also, I plan on doing some F/I down the line. IS THERE ANYTHING MISSING besides F/I Itself? Want to get as much done as possible while the whole drivetrain is out!
New Cam Sensor
New Coolant Sensor
Reman Starter
A/C Delco Plugs
Used Crank Pulley
New LS7 Lifters
411 PCM
New 2wd Actuator
#30
Custm2500's Rude Friend
New Cam Sensor
New Coolant Sensor
Reman Starter
A/C Delco Plugs
Used Crank Pulley
New LS7 Lifters
411 PCM
New 2wd Actuator
New Cam Sensor
New Coolant Sensor
Reman Starter
A/C Delco Plugs
Used Crank Pulley
New LS7 Lifters
411 PCM
New 2wd Actuator
1999-2000 Silverado came with 09354896 PCM
2001-2002 Silverado came with 12200411 PCM
The 411 Pcm with the later Operating System is typically more popular because there are more tables to tweak if you are running forced induction.
These 8 digit service numbers were used in other vehicles during those year ranges as well.
What is a 2WD Actuator for the 4L80E???
I have heard of a 4WD shift actuator for the front Differential and a Transfer Case 4WD Actuator, But nothing for the transmission itself.
