ls1 hotcam
#22
#23
why do people insist on the hot cam? There is nothing special about it. It's just GM's performance cam offering. You can get any cam you want from comp for $400.
#25
If your buddy is building the motor to rev high why not get a bigger cam that will kill up top? Seems kind of pointless to get a sub-220 cam with a low LSA for a high revving motor. Since it's a sport truck I'd go wild with it.
#27
comp 216-220 is a good cam to go with on a low stall. i had it in my old chevy and it worked great,. that was with the factory verter stalled to 2400 and a good tune. and it was my belief that the ls6 springs werent any good with cams over the 550 lift. if you are going to go thru the trouble and maybe make a swap later i would go with the 918 springs and do it once.
#28
the hot cam is to big for you!
People need to calm down on these huge cams. Elaborate on what you are wanting. If you want a snappy throttle with just more low end and al ittle more top end I woud look at a custom grind in the area of 208/212 or 210/212. Great for torque, anything bigger will only pull torque into your higher rpms and create more HP at 4500 + rpms.
#29
That's one of the reasons I went ahead and did this cam because I don't want to worry about drivetrain wear any time soon, although heads are in the near future now. Another reasoning is if a GMPP engineer designed this cam for their LSx motors to be a street performance cam it's going to get its full potential for it's dimensions. I would rather have gone with a TR224 probably, but didn't want that much lift. In a nutshell, a lot of people are against this cam but it makes great power across the board. I'll have new dyno numbers on spring break once the new tranny is in.
i agree^^^^
i myself was thinking of using the hot cam myself,people say its a good cam but there is better, which i agree.
but?
running a 212-218 how much lift is to much on a stock 5.3 no head work no springs.
or do i gotta do some springs and push rods with a cam as mentioned above?
my truck is a daily driver in dallas,tx and its a 97 swb 5.7
fixing to convert to the 5.3 but i wanna do a cam swap first while its out.
so i dont want to damn radical because i have to a bit of driving.
thats why i was thinking of using the hot cam myself.
so whats your thoughts.
thanks
Ed
#30
why would people not like it. i ran a lt4 hot cam in my older truck and i loved it,for everyday driving. i would like to know what is better myself?
i agree^^^^
but?
thanks
Ed
i agree^^^^
but?
thanks
Ed
IIRC, Charlie's cam is low lift somewhere in the range of the hot cam's lift around .550'ish? You still should change the springs, and if you want peace of mind I would change the pushrods as well. They weren't "required" for the hot cam, but I run the motor to 6200 and don't want to even think about the stock pushrods failing.
If you daily drive the truck the smaller cam would probably be wise, but if you want to put in a higher stall the hot cam would most likely be quicker.
