LS2 head vs LQ4 head
What is difference in these two heads?
It appears the LQ4 head has bigger cc's and smaller runners?
Does the LS2 head have smalller cc's and larger runners?
ALSO
Would a stock LS2 cam be OK with stock LQ4 valve springs?
Thanks
ALSO
Thanks
basically the same head in theory! LQ4 head "317" and LS2 head "243"
317 - same runners and flow as the 243. 72cc combustion chamber
243 - same runners and flow as the 317. 64cc combustion chamber
WAY too much to be milled off the 317 to get the 64cc of the 243.
You be the judge, but i would think you could use it
LS2 cam specs: 200/203 - .500/.500
LQ4/9 cam specs: 196/207 - .467/.479
