LS2 timing chain discussion
Sexy Party Mod
Ok I should know this but, the ls2 timing chain, (from what i gathered from a search, yes i did a search.
) part number 12586482 can be easily switched out in place of the stock timing chain while reusing the stock sprockets? I just want to make sure that this info is correct before i go ***** first into my camswap....again.
With 96k miles on the clock, do you think its worth it to go through the trouble to change the timing chain out? As always, opinions and comments are entertained. Thanks for reading!
![Rolleyes](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/rolleyes.gif)
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
5 year bitches!
i had run the ls2 timing chain before and know other ppl with same setup. as long as your stock sprockets are low in miles or dont have much wear to them then yes only buy the chain
Truck addict
just added strength. i am in the same boat, i have a ls2 timing chain here waiting on install but i think i'm gonna keep waiting till i decide which motor to go with. 6.0 or iron block 5.7
Sexy Party Mod
Originally Posted by Soon2bSpooled
why dont you go with a roll-master double roller chain from FMS for 90 bucks? im not sure if it comes with the sprockets
![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
