LS6 cam and springs
Old 10-17-2005, 06:24 PM
Keith's Avatar
Originally Posted by TN_TRITON
Yes, it would probably make go further but, I am afraid to turn the stock bottom end much further.
How was tuning for this cam?
Old 10-17-2005, 06:27 PM
FILE's Avatar
Don't be afraid, I am turning my stock bottom end to 6500 with no problems.
Old 10-20-2005, 07:49 AM
Registered abuser
1BadAction's Avatar
did you loose much bottom end torque with the ls6 cam? im thinking of doing one in my 5.3 but I tow, so I don't want to loose 1-2000 torque that it has now.
Old 10-20-2005, 09:07 AM
TN_TRITON's Avatar
I did not lose any bottom end. I still tow my 21ft bassboat every weekend with the truck.
Old 10-20-2005, 10:29 AM
Registered abuser
1BadAction's Avatar
kewl... sounds like a good cam for me.
Old 10-20-2005, 03:21 PM
custom 68's Avatar
dont forget there are different ls6 cams I think they changed in 02 they are a bit more aggressive... atleast on the top end.
Dave
Old 10-20-2005, 04:06 PM
TN_TRITON's Avatar
Yes there is. I went with the 2001 LS6 cam because I felt it to be more suited to a truck because of the lower lsa.
Old 10-26-2005, 11:29 AM
'00 Buck's Avatar
01 LS6 207/217 .525/.525 116* part #12560950
02 LS6 204/218 .550/.550 117* part #12565308
I keep finding conflicting info as to cam specs, these are off the gmpartsdirect.com website. Some info I have shows the 01 cam used in the LS2, others show the 02 cam was used. The LS7 cam is even higher lift, not even the same (but then it's in a 7.0L 427ci engine). Either way, both of those cams were designed with emissions in mind and I know several guys that have one or the other in their trucks and like 'em. We just started the sniffer test here in Austin this year so it's something to think about. I'm still leaning toward the 01 cam when I get the money & time to do it.
ARC
57
02-21-2022 10:54 AM
chevyl33
08-24-2015 08:21 AM
Offroadunleashed
07-20-2015 02:25 PM
Aboss
07-09-2015 10:28 AM
07NBSChevy
20
07-08-2015 07:27 PM
Quick Reply: LS6 cam and springs
