LS6 springs with a vinci 216 224 .551 .551 -115??
Old 07-08-2010, 10:12 AM
2000silvrx81's Avatar
Default LS6 springs with a vinci 216 224 .551 .551 -115??
do you think ls6 springs would be enough for my app? i hear alot of pros and cons on springs on this website but i never really hear any bad beef on the ls6 springs in low lift apps like this. let me know your thoughts and if you have ever had this combo or close to it before.
Old 07-08-2010, 10:37 AM
EVILGMC's Avatar
might be a little too big for ls6....get some PACs or patriots for cheap insurance.
Old 07-08-2010, 10:40 AM
sharpshooter's Avatar
I've been running this set-up for over 2 years now.Sureshot runs the same in his.
Old 07-08-2010, 10:41 AM
the ls6 cam i have right now has 551-547, that is the only reason i was questioning it. i know this has 551 straight across. the only thing that is much different is the duration
Old 07-08-2010, 10:42 AM
so you use ls6 springs?
Old 07-08-2010, 10:46 AM
the yellow ls6 springs
Old 07-08-2010, 10:48 AM
what p/r? ive got a set of ls6 p/r also.
Old 07-08-2010, 11:20 AM
PT's Slowest Truck
budhayes3's Avatar
Roger Vinci himself says that those springs will be fine with that cam, that's what he told me when I bought the Trucker and I told him that I already had yellow LS6 springs in my WCCH StageII 317's. SDPC used to sell a Crane 220/224 .551/.551 114, which is also a Vinci Stangbanger, and they recommended the yellow LS6 springs for that cam which uses the same style lobes, has the same lift, only with more duration. You will be fine
Old 07-08-2010, 01:25 PM
Preston129's Avatar
Try to confirm the individual PN of the springs is 12586484, as those are good to .570".
Old 07-08-2010, 01:34 PM
stranger ranger's Avatar
I recently spoke with roger as well, and he suggests the use of his heavy duty dual springs with his "butt kicker" cam that I inquired about.
Ls6 singles or heavy duty duals?
pros, cons?
Quick Reply: LS6 springs with a vinci 216 224 .551 .551 -115??
