Lunati Gold Dual Valve Springs
So who's running these? They're the most inexpensive dual valve spring kit that I've seen available, and I've always had great luck with Lunati products in the past. Seems the complete kit runs around $210 and can handle .660 lift...comes with everything you need to install these springs...
http://www.abad71camaro.com/catalog/...sbl_4136_1.JPG
http://www.lunatipower.com/Product.aspx?id=2584&gid=322
Originally Posted by LunatiPower
Product Description
With a maximum lift capability at 0.660-inch, the Lunati kit serves the majority of popular camshaft applications. The kit is complete with dual valve springs, steel retainers, locks, valve seals and spring locators and represents a drop-in installation for many popular LS applications. Lunati’s retainers and spring locators are CNC-manufactured from 4140 alloy steel. The locators pilot onto the valve guides and locate the inner diameter of the inner valve springs, preventing them from abrading the spring pockets in the aluminum heads. In common with all dual-spring retainers, these new Lunati types have a group of steps machined into their underside (which locate the upper registers of the valve springs) and a bore machined to accept the 7-degree valve locks. The locks are equipped with inner bead locks and the 7-degree interference angle between the locks and the retainers is favored by many who believe it causes the locks to clamp the valve stems tighter. Through careful CAD and FEA design efforts, Lunati engineers have developed a new valve spring retainer design using wear-favorable alloy steel, yet nearly matching the weight advantage of Titanium. For street/strip longevity, Lunati’s lightweight alloy steel retainer is unbeatable. Viton steel-jacketed valve seals complete the kit. The steel jackets ensure the valve stem seals remain tight around the valve guides and also protect the seals should the inner springs come in light contact with them. The Viton material is ideal for resisting heat and oil, particularly some of the more aggressive oil additives that cause ordinary seals to swell and distort.
silverstreak07
06-28-2016 06:29 PM
