Main Cap and Rod Bolts
Old 01-17-2011, 10:33 PM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by Robert91RS
If I remember correctly, use of ARP rod bolts requires machining of the rod to bring it back into spec. The higher clamping force distorts the rod.
I had read this a long time ago also, but if you ask any of the guys here at PT.net who have done ARP rod bolts, all they have done is remove the sleeves from the factory bolts and torque the ARP's as necessary
Old 01-22-2011, 04:29 AM
chrisfrost's Avatar
Hello , I don't know if You still need part#'s but if so , the mains are #12560272 (10) , # 12560273 (10) . Those are the large bolts and the studs . I don't have the side bolt #'s or the rod bolt #'s handy . If You need those also You can reply on this thread and I will dig them up for You . Good luck
Old 01-24-2011, 04:54 PM
Steve-O-08's Avatar
Sweet, thanks.
5.3Okasai
03-09-2022 01:07 PM
greedygenius
09-03-2015 06:51 AM
Jake75
08-05-2015 01:26 PM
steves86ta
07-28-2015 10:21 AM
Ammadien
07-22-2015 08:50 PM
Quick Reply: Main Cap and Rod Bolts
