Mosquito Fogger Mod Done - Suburban "build thread"
Old 02-16-2012, 06:43 AM
TXSZ66AVLANCHE's Avatar
Originally Posted by tylertxss
U'll have to tow it to the elementary to crank it, its gonna be a beast!
I left my recovery hook on the back of your truck
Old 02-16-2012, 06:48 AM
Originally Posted by sprayedenali
its nice to see someone actually rebuilding an engine and not just throwing a junkyard motor in there.... what cam did you end up using?
Thanks, I dont understand why people throw untested junkyard engines in their trucks either. These engines are easy to put together, really the only special tools you need is a torque wrench, puller, and torque angle meter.
Long as you use a trusted machine shop to grind and polish the crank, clean and hone the block, and install the cam bearings its hard to screw it up. Even though I know the torque specs I still make it a habbit to use my engine book just to make sure its corrrect.
Old 02-18-2012, 04:21 PM
Well the engine is done, moved it to my house last night, but weather is not being nice today.
Old 02-26-2012, 07:40 AM
Yesterday my buddy Jay helped me remove the old engine, the new engine is sitting in the truck but still needs to have everything finished up.
Old 02-26-2012, 08:19 AM
1fas92's Avatar
Great looking build -resurrection !!
I can't wait to get mine back on the road again !!
There will not be just one wheel spinning !!
Old 02-26-2012, 08:37 PM
Finished up everything today, engine runs great and makes real good power for a tiny 5.4. sorry fellas no idle clip....nobody wants to hear stock exhaust!
Compared to a stock 5.3 the flat top pistons and LS1 cam make a good jump in performance and did not cost one cent more than using the dished pistons and stock truck cam.
Old 02-26-2012, 11:04 PM
Lucille's Avatar
TXS- noticed the signature change. Best choice on the Avy for the 427
Old 02-27-2012, 05:31 AM
Yeah, the 427 is going to be fun, long way to go $ on the LSX block. There are some parts needed on the LSX that are unique and not borrowed from the production side. The rear cover is one for example....that 3lb piece of aluminum is quite expensive!
Old 02-27-2012, 06:57 AM
Last night I put about 40 miles on the truck after breaking in the engine for about 30 min in the driveway, holds 75-80 on the highway with very minimal throttle. The old tired 5.3 struggled to hold 70 without constantly applying enough throttle to down shift the transmission, any hills or headwind would completely bog it down.
Overall I am very pleased with the results, the added power of the new flat top pistons and new LS1 cam are a decent upgrade. I think the main power difference comes from the compression ratio jump from the stock 9:5.1 to 10:5.1
Old 02-29-2012, 08:07 PM
Pic of the new engine partially installed from the other day.
Anyone want to buy a low mile 223K engine?
Here is what happened to the old engine, broken piston.
Quick Reply: Mosquito Fogger Mod Done - Suburban "build thread"
