Need dyno 206/212 .515/.522 112LSA in a 5.3
Know that the lift numbers are not the only difference between the two cams. The valve events are radically different between the "low-lift" and "high-lift" versions.
Personally, after reading quite a few threads on here between the two and seeing some dyno graphs, I'm convinced the low-lift version is still the better performer.
so I've been doing a lot of reading getting prepped for the swap and one of my main questions is if i have to remove the ac condenser or if i can just move it out of the way enough. i have a 3'' body lift if that makes any difference
well i thought i had made my mind up and i kept going back and forth trying to make my choice. Today i ordered the xr259hr, rods and springs. I know almost everyone was pushing for the xr265hr but in the end i thought that for me since i spend most of my time in the lower rpms, that i would be more satisfied with a cam that provided more torque in my regular driving range.
i have a servo in my trans right now and an external cooler, should i do the transgo stage 2 shift kit right away or do you think i can wait a while before getting it?
Curious what springs you went with? Back when I got my cam, I was originally running Comp 915's (as per my pop's Comp rep's recommendation). I later swapped them out for the yellow LS6 springs that I'm currently running. If you went with Comp 918's, you may want to do some searching around here and on LS1Tech and see how many pics of broken 918's that you come up with...personally I'd never mess with them. LS6 springs are more than adequate for that cam, or if you want something that will allow for room to grow, I'd go with the PAC 1218's which have an excellent track record
I like my gt2-3 cam in my lq4, I'm not convinced the big cams really gain all that much on a mild setup. Part throttle power is awesome. Yes bigger cams gain up top but you need power down low when you're cruising along in 4th with the tc locked. I can go up pretty much any hill with the tc locked and my tight converter makes for a great driving combo.
I have a 222/226 600 in my LQ9, and it's noticeably soggier cruising on the highway than the stock cam. Part of that may be my tuning, I don't know, although I've spent literally hours fine tuning it with a wideband. That being said, it still pulls hills fine. I did get a chance to drive a stock 4WD ecsb 5.3 3.73s, and it definitely feels peppier off 0-1500 rpms than my truck does with the 4l80e.
There was a magazine article a couple years ago comparing 6.0L cams - varying from very smallish ones all the way up to a 224/230 cam. The 210/218 Vinci cam outdid all the other cams in HP and TQ up to 4800 rpms.
