Need dyno 206/212 .515/.522 112LSA in a 5.3
Old 06-24-2011 | 02:18 PM
  #21
gregs323's Avatar
You're going to like that cam, as I mentioned, it's a definite improvement over stock, and is totally stealthy. I drove mine for about 5 years on the stock torque converter too. You can hold off on the shift kit for a while, I never had one with mine, until my trans blew lol, but I ran the stock trans with 0 torque management for about 23k before it chucked.
Curious what springs you went with? Back when I got my cam, I was originally running Comp 915's (as per my pop's Comp rep's recommendation). I later swapped them out for the yellow LS6 springs that I'm currently running. If you went with Comp 918's, you may want to do some searching around here and on LS1Tech and see how many pics of broken 918's that you come up with...personally I'd never mess with them. LS6 springs are more than adequate for that cam, or if you want something that will allow for room to grow, I'd go with the PAC 1218's which have an excellent track record
for springs i was going to go with ls6 springs but i couldn't find then on lingenfelter's website so i called them up and they said the ls6 springs had been discontinued and replaced with ls9 springs, so that's what i'm going with.
i am currently running 0 TM, and i'm not sure if i'm going to do a shift kit or not
Old 06-30-2011 | 11:51 AM
  #22
gregs323's Avatar
Well I got the cam in, i took my time and everything turned out great. Its a nice improvement over stock, the acceleration is awesome it climbs the rpm so fast now! I'm running it on my old tune and so far it looks like fuel is only off by a little bit in the lower rpms. I did bring my idle rpm up to 600 rpm, it was loping pretty hard at 525 rpm and spark was spinning all over the place. At 600 rpm the spark is a lot more smoother. I haven't really rapped out the motor yet so i don't know what the fueling is like up top.
Old 07-26-2011 | 12:15 PM
  #23
gregs323's Avatar
loping sound clip:
‪206/212 .515/.522 112 lsa in 5.3‬‏ - YouTube
Just an update, i'm loving this cam i'm very pleased with it. Ran it in the 1/4 on a nasty hot and humid night and it ran a consistent 16.2 on a 89 octane tune. Will be taking it back when a cooler night shows up & will run my 93 octane tune and see what happens.
Old 07-26-2011 | 08:08 PM
  #24
andrew383's Avatar
traveling mod
Sounds good..I plan on a similar cam for the 5.3 going in the jeep
Old 07-27-2011 | 05:15 AM
  #25
06Sierra2's Avatar
Originally Posted by gregs323
loping sound clip:
did u ever run the truck before the cam swap?
Old 07-28-2011 | 11:36 PM
  #26
gregs323's Avatar
unfortunately i never did, i'm not very impressed with the times but its been so crazy hot here lately 100* with 95% humidity
UPDATE:
on 10/08/11 it ran 15.599 at 90.3 on a 91 octane tune
outlawz2004
09-19-2015 09:12 PM
Greatdivider
09-09-2015 10:52 AM
dselby25
08-24-2015 08:26 PM
So.cal Wrk Sled
07-26-2015 01:10 AM
cammed06
07-24-2015 01:09 PM
