need a egr tube
Block off the EGR bung on your headers with some flat stock and stuff some foam filter material up into the tube. Exhaust goes out the exhaust and filtered air passes through the EGR when the PCM commands the EGR to open. This method has been working for nearly 10 years and never got an EGR DTC code. Using EGR is the most efficient way to clog your entire intake with SOOT(EGR). I have not been able to find a chimney sweep small enough to fit inside my intake which is what you need if you leave EGR connected. Ford makes thousands every day on the F 150 trucks cleaning intakes clogged with EGR soot. Sad thing is that as soon as the customer drives that Ford off of the lot the soot starts to clog the intake all over again. What a system. Got to love EGR.
