Need help identifying these yard sale heads.
My local performance shop said they looked badass. Im going to have him give them a good cleaning and once over. My new 350 build will be around them. The valves are 202 so they should flow well and since my cam is a 479 lift he said double eyebrow pistons would clear valves just fine. All i need now is some big rockers.
11 Second Club
Have you personally measured the valves yourself? Just curious
Ps, if you do a bit of googling with the casting numbers you will figure what heads they are, what they fit and what block they came from. It is a bit time consuming but worth the end result, you may be dealing with 307 boat anchors instead of high comp 400 heads..... See my point
good luck fitting an intake on that.
i had some early sportsman heads milled to 58 and it was a nightmare getting the intake on it right. i had the cut down the intake a ton where it bridges the lifter valley, and i had to use really thick gaskets.
