need a titan killing cam for my 4.8
#21
hmm, this is the stall i am currently running now with a na 5.3. i plan on spraying it next year though i might wait now and run the 3400 billet stall after reading this. i want something thats gonna eventually handle a 6.0 h/c/i with about a 100 shot. for the op, i dd a 3200 and would still def dd the 3400 easily. alot of people still dd 3600 and higher but that would be a litlte much for my taste i think.
#22
tr220 110lsa 4 degrees advance. the 214 564lift seems way small for a ls6 head even for a 4.8. And did you mill the heads? if not your like 9.2?? cr witch is way to low to even put a cam in unless you got a 3500+ stall. The other cam is good too tho
#23
The compression on this motor is 9.4.and how much should i mill the heads? and do i need to use a thinner head gaskets? How much compression do i need to get the most out of that cam?
#25
#30
<-this truck in my avatar is the one.you guys talked me into it,i will go with the swap since its gunna take more than a cammed 4.8 to move that beast.i will start my search for that rotating assy.
