New guy needing help with '99 5.3l
I wouldn't think so. I had a 216/220 cam with LS6 springs with the stock stall for a couple weeks and the thing felt great everywhere.
You can always get the cam now, and if you aren't real happy then save up for a ~$400 converter.
•Advertised Duration (Int/Exh): 262/268
•Duration @ .050 (Int/Exh): 212/218
•Gross Valve Lift (Int/Exh): .531"/.531"
•LSA/ICL: 113/109
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1400-6200
•Includes: Cam Only
Part Number: 60510
lunati voodoo I have in my truck used the springs lunati recommended runs great with stock converter but I can tell it needs tuned. It will still **** and get compared to stock though lol. Really wakes it up all over the rpm range.
•LSA/ICL: 113/109
•Includes: Cam Only
Part Number: 60510
I have this exact cam in my ex cab 4.8 and it runs superb. Good power throughout, but really starts pulling around 2500+rpm. It will not like to idle in gear very well before you tune it though, so if you end up getting it, make sure a tune arrives soon after. Also welcome to PT
I have an 01 ECSB with 4.8. If one was to go with this cam set up what would you do for heads?
