New Project
Former Vendor
OK so the 4" stroke with the 3.905 bore will give me 393ci.
What is the stock cr and should I change it? I plan on only going about 15 lbs of boost with the STS kit. I have read that the stock block can easily handle 10 psi and with proper tune 15-20 is possible.
Former Vendor
Can I keep the stock cr and still do 10-15 psi safely? I would prefer this because I would have more pep off boost. If I have to lower cr to be safe though I will do it.
Former Vendor
The 5.3 has a 10:1 cr then? Is 15 psi ok with a 9.5:1 cr and an intercooler? I might add a meth kit also.
If I add a meth kit would it damage any sensors(MAP, MAF, AIT etc.) that come after it?
Former Vendor
I came accross a LQ4(iron 6.0) for $600 plus $200 for the heads if I want them. Is that a good deal? Should I use the heads as is or have them p&P? Would there be any benefit since I will be runing 15 psi?
What intake would you guys recommend?
