No oil pressure when cranking - 6.0L
#21
i had a feeling it had something to do with the oilpan i didnt even notice it had a custom one until i saw it and re-read.
i know on my truck i say oil pressure when cranking , let us know if you get it when you try and prime before initial start. sucks you had to pull it though .
Biggest waste of money in the project was this damn oilpan setup.
I was dreading pulling the motor just because I was so close to having it started, but after my 3 year old went to bed at 9pm, I had the motor disassembled, pulled, and all fixed ready to go back in by 1am. Not too bad being super tired and by myself. I have my dad coming over today to give me a hand getting it back in. Last time I put the motor in myself and it took me forever to get it in correctly, so having help this time should prove to be beneficial.
#22
Well the motor is back in and all back together. When taking off the crank pulley, I ended up breaking the pulley, so I had to order another one.
Think there is anything wrong with trying to crank over the motor without the harmonic dampener? What about idling the motor? Should I wait, or will it be ok to start it up?
Edit: Nevermind, I found one locally and picking it up tonight.
#23
Just in case someone comes across this in a search, I DID get oil pressure when cranking once this was fixed. I have oil feeding the turbo and circulating nicely. Amazing how a little air leak can cause such a problem. It took about 20 seconds of cranking, but it eventually started flowing.
Should hopefully have the truck started for the first time tomorrow.
superchomper2003
08-26-2015 09:39 AM
05GMC4.8
08-07-2015 09:55 PM
Ferocity02
07-17-2015 07:05 PM
