NOISY valvetrain after highway trip??
Was on the highway for an hour and a half yesterday crusin 70-75, traffic got stopped on the 2 lane cause of construction. So while i was waiting i put it in neutral and noticed the valvetrain was extremely noisy. Oil pressure normally only gets down to 50 in town at a light and is around 55-60 while driving, but when i stopped on the highway it was floating around 40-45. Running mobil 1 synthetic 10w30 6qts. When i got back up to speed you couldnt hear it. And then driving back that night it wasnt as noisy. The motor was set up for a factory oil cooler but i put the block off plate from my 5.3 on it. SO my question is does it sound like i need an oil cooler? Sorry for the long post
Were you sitting next to a divider on the highway in traffic? That will increase the noises that you hear tremendously...I experience this on a daily basis on my ride home from work on Rt4 west The engine/drivetrain noises will bounce off of median/divider between the two sides of the highway and you'll hear **** that you've never heard before.
Your oil pressure numbers look good and consistent with what I've noticed on these trucks through the years...you could do a few checks for poops and giggles, maybe take a sniff of the oil and make sure that it isn't getting diluted with fuel indicating a rich condition.
Baltimore Whore
^^^^^ good observation Wally.. This is def true.. Have you since listened to the truck out side of it at idle?? Thats the first thing I would do.. No real red flags as of yet.. Like said check the oil, if it checks out, I wouldn't sweat it. Initially I was thinking broken valve spring, but seems as if it is not..
There were not any dividers since its just a two lane highway and they were re-paving one side so i was sitting there in the open. lol i try and turn the radio up when i drive by dividers or else i go paranoid crazy. Driving around town its noisy but not that noisy. I've come to terms that ls engines with a larger cam are noisy but this was ridiculous. I have not sniffed the oil but it is clean, i just changed it this past saturday from 5w30 mobil 1 to the 10w30. Im pretty sure its not a broke spring cause its not very noisy all the time(running prc .650 duals) It seems to only happen when on the highway for over 30-45 minutes. Ive listened to it since Wednesday and it sounds like it usually does, a little chatter but not too bad.
