odd cam speced by pat g?
It's a good spec for what you said you wanted. If you aren't happy with the cam specs, tell him you would like the intake side bumped up a tad, but then the lift is going to be higher and other things might change as well.
I would honestly rather it perform better than it sounds, I just don't want a stock or close to stock idle, but I wouldn't mind a hard lope. It just seemed odd for him to recommend such a wide split.
i have a comp 689-421-13 dod/vvt camshaft with 214-226 duration 500 lift for the dod lifters.but i have yella terra 1.8 ultralite shaftmount rockers that will put me over 530 lift and still run dod.
