oil to break in stroker engine?
Old 03-23-2008, 05:53 PM
xdanny510x's Avatar
Default oil to break in stroker engine?
which oil should be added along with the break in lub to a new stroker engine? i heard Vr1 20-50 racing oil is this true? or if someone knows plz chime in
Old 03-23-2008, 06:12 PM
dirt track racer 81's Avatar
i just put in some cheap oil..gave a few miles then changed it then i put in some valvoline 10w 30..im sure some one else with chime in with better ideas that sound better
Old 03-23-2008, 06:58 PM
fastnblu's Avatar
I'm not a builder, but I'd say break it in w/ conventional oil, then later, if u want, run synthetic. Good luck.
Old 03-23-2008, 07:01 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
what does the builder recommend? btw congrats on the new setup, hope to see it at the track sometime.
Old 03-23-2008, 07:28 PM
Mort's Avatar
We ran some cheap oil through to flush it out. Only a couple of good warm ups really and my builder told me to use a good quality 10W30. It is a lot colder here than California so I am using Castrol GTX 5W30.
Old 03-23-2008, 07:38 PM
LS1Tech Sponsor
Slowhawk's Avatar
First,as said you ask the builder. We personally run Valvoline 10w/40 to break in the motor. We run it for about 15 minutes,change it,then run it again for about 1k miles. That is for a street motor.
Old 03-23-2008, 08:55 PM
Okie5.3's Avatar
What Slowhawk said, only to add, I prefer a conventional non-detergent oil in a weight based on the bearing clearences for the initial startup and ring seating. Afterwards use whatever type you want based on the bearing clearences.
Old 03-23-2008, 08:58 PM
also if you are going to switch to synthetic oil id run it on conventional oil a while until the rings get seated in
Old 03-23-2008, 11:01 PM
xdanny510x's Avatar
askd the builderand he said valvoline Vr1 racing oil 20-50 to break in the motor ..
Old 03-23-2008, 11:44 PM
LowBlack99's Avatar
I'd go with the builder then. I'd run regular oil for a few miles then switch to the oil you intend to run all the time if it were mine. I'm no engine builder though.
Quick Reply: oil to break in stroker engine?
