oil pressure problem - update
Follow up to:
https://www.performancetrucks.net/fo...0-rpms-489650/
Well, I thought of trying something out today. Hooked up my laptop, cranked the engine, drove around the block until the oil temp went up to 140F, then I floored it and recorded a peak oil pressure reading of 60PSI.
10minutes later, oil temps reached above 196F, I repeated and did not see more than 50PSI this time.
That taking into consideration the car will get to and beyond 200F in this weather especially since it has no oil cooler YET.
Im waiting to hear from SLP on the recommended oil viscosity for this engine, ill use that and with an oil cooler I think I might be good but thats just a guess.
What do you guys think?
Thanks for the reply. I actually heard back from SLP, they built the engine and recommended I use 15w-50 oil on this truck and also install an oil cooler. If I do both I am sure I will see 60ish PSI, which should be perfect
superchomper2003
08-26-2015 09:39 AM
05GMC4.8
08-07-2015 09:55 PM
Ferocity02
07-17-2015 07:05 PM
