oil pressure question
Old 05-01-2007, 10:41 PM
adam1803's Avatar
as i said before, both plugs are installed, they were the first things i checked.
Old 05-01-2007, 10:43 PM
5 year bitches!
Quik's Avatar
and you stil ldont have psi...did you pull apart your pump? its simple unless your pickup tube screen is blocked
Old 05-01-2007, 10:52 PM
adam1803's Avatar
I didn't pull the pump apart since its brand new, i don't really know what to look for inside of it either. The next thing im going to try is change the pump out with an old one i've got sitting here. While im at it im going to take the pan off and check the pickup tube too, don't know what could be blocking it though. Unless the spacers from the main stud kit are putting it too far into the pan.
Old 05-01-2007, 10:59 PM
quicksilverado's Avatar
I had a small sliver of metal get into mine and lock it up.
Old 05-01-2007, 11:00 PM
adam1803's Avatar
Into your oil pump or your screen?
Old 05-02-2007, 10:15 PM
adam1803's Avatar
tonight i took off the oil pan and checked the pickup tube and it is not blocked. I then changed out the oil pump with one that i had sitting around. Before i put the oil pan all back together i had my wife crank the truck over while i put my hand over the pickup tube, i felt absolutely no suction at all. Im at a loss here as to what to do.
Old 05-02-2007, 10:41 PM
5 year bitches!
Quik's Avatar
did you try and blow air thru the pick up tube? maybe somethign is lodged in the tube
Old 05-02-2007, 11:02 PM
adam1803's Avatar
I took it completely off and poured oil through it, it flowed through just as fast as i poured it in.
Old 05-02-2007, 11:03 PM
5 year bitches!
Quik's Avatar
then dont knwo but, your problem sounds weird
Old 05-02-2007, 11:08 PM
adam1803's Avatar
yeah i am stumped. I think im going to just order a new pickup tube, oil pump, and oring. Then force oil through the motor with a hand pump. That way i'll know the bearings have some oil on them and i will start it up and let it run 15-20 seconds and hopefully i'll get oil pressure. I just don't understand what the hell is going on here.
Quick Reply: oil pressure question
