Oil pump pick-up tube, what color for best oil psi?
I'm getting everything together for my cam swap while Im in there im going to change the o ring cause my oil pressure is alittle off right now from the last cam swap and o ring that was installed.
What color o ring will give menthe best oil psi? I remember reading about stacking them to get more psi but idk how safe that is.
Good info:
https://www.performancetrucks.net/fo...number-470514/
Rick
Thank you for that link Rick, has the part number and all the info I needed. And I wasn't planing on stacking them I just heard it somewhere and wanted to see if you guys had ever heard of it being done.
Ferocity02
07-17-2015 08:05 PM
