oil pump or spun bearing??
11 Second Truck Club
Also, this is just my opinion, but I am very picky about cleanliness when I tear apart an engine, I would do your very best to get as much of that metallic sludge out of everything as possible. I wish you could prime the oil pumps on these engines like you could with the distributor drive on sb/bb chevy's to flush it out.
what can i look for, as far as low oil pressure problem? i know the lifter being how it was, was causing the low oil pressure after it went out. but what would cause low oil pressure before the lifter was smahed?
as far as cleaning everything up, ill be spending several hours and alot of parts cleaner get everything clean. it has been bothering me that the oil came out the way it did, cuz that means everything has **** in or on it.
the truck isnt my dd anymore. i love choppy idles, and the way Slowlsx's truck sounds nasty as hell, and ifmine sounded like that it would be sick. But id like to really just get the best power and performance from it. i have 4.10's and a 3400 stall. with my 218/224 .600/.605 111lsa cam it woud spool fast, and pull hard. my trucks sweet spot was from a 50 roll, anything under it would spin.
so i want to get the best performaning cam period.
thanks for the info. Jake (smokeshow) has been explaining turbos and cam working together. i know im limited to what the s465 will put out. but eventually ill have to get a s475 haha.
jake always make fun of me cuz i want my truck to lope like crazy weither it helps or not haha. so id like to get a bigger cam.
im leaning toward the 228/222 115+2 cuz i might get it cheaper then $400
High on diesel fumes
So I picked up some parts plus some are on order.
Stuff I have
1. Ls7 lifter
2. Ls2 lifter trays
3. Arp cam bolts
4. TSP ported ls6 oil pump
5. Front cover gasket
6. Water pump gaskets
Stuff I'm waiting on
1. Isky "Triple 12" cam
2. Ls9 head gaskets
3. Cam retaining plate w/bolts
4. Oil pick tube O ring
5. Gm header studs
Everything but the cam should be here tomorrow. So I can star putting stuff together and finish cleaning it all.
Going a few weekends with out the truck sucks. Glad I have a DD to rock out in
Stuff I have
1. Ls7 lifter
2. Ls2 lifter trays
3. Arp cam bolts
2. Ls9 head gaskets
5. Gm header studs
Looks like a pretty good combo of parts you have there, very similar to what I'm using except I am using a 218/218/112. That triple 12 seems to be working very well for someone else on here, don't remember his name..
