oil pump or spun bearing??
#24
Truck is back together. Had an issue with the pick up tube o ring. I was using an orange o ring. It would have pressure at idle for a lil bit, but slowly bled off. While giving it gas 2000/2500 rpms, oil pressure was fine. So I replaced the orange o ring with the red o ring. And problem solved. Oil pressure at idle with this new tsp ls6 oil pump is constant 50 psi. If I touch the throttle, 2000rpmsm oil pressure rises quickly and goes to 80psi. So oil pressure should not be a problem for me any more. Hopefully today I'll be able to get it tuned. And we shall see how this Triple 12 does I'll keep updating
