Opinions on this 5.3 cam?
Originally Posted by FarmerBeau
For a Naturally aspirated application?
Yes. My motorcycle makes more cylinder pressure at 103/105 lobe spaceing than it does at 106/108...
It makes better TQ below 8000rpms like that and with the higher LS it makes more TQ above 8000rpms...
Sexy Party Mod
The lobe spacing has as much to do with low end TQ as the duration as well as overlap for low end TQ - less overlap the better...
.........................Varying Lobe Separation Angle.....................................
...............Tighten............................ ..............Widen
Moves Torque to Lower RPM..............Raise Torque to Higher RPM
Increases Maximum Torque................Reduces Maximum Torque
Narrow Powerband...........................Broadens Power Band
Builds Higher Cylinder Pressure............Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock........Decrease Chance of Engine Knock
Increase Cranking Compression...........Decrease Cranking Compression
Increase Efective Compression...........Decrease Efective Compression
Idle Vacuum is Reduced....................Idle Vacuum is Increased
Idle Quality Suffers..........................Idle Quality Improves
Open Valve-Overlap Increases...........Open Valve-Overlap Decreases
Closed Valve-Overlap Increases.........Closed Valve-Overlap Decreases
Natural EGR Efect Increases..............Natural EGR Efect is Reduced
Decreases Piston-to-Valve Clerance....Increases Piston-to-Valve Clerance
Tin Foil Hat Wearin' Fool
I ran that cam in my heavy *** truck with a 3K and it was a bit sluggish on 32" all terrain tires. You need something in like comps 212/218 on a 114 it wont have much lope to it but it will make the truck run well with a 3K stall and tall tires. With those tall tires and the relatively small size motor you are limited on your choices to get what you are wanting out of that combo. The best thing he could do to make it faster is either drop the tire size or swap a 6L into with the cam I stated and it will be a tq monster but wont have hardly any lope to it.
If the LSA is 114 the overlap can be 38/48/or 58 degrees... They do not have to be one in the same.
And it also depends on which type of overlap you are refering to...I was refering to Closed and smaller LSA's...
I am confusing sometimes but i almost have a clue....LOL
I'm running a similar cam, the tr224. the specs are 224/224 .563 .563 on 114lsa. i have a 00 rcsb siverado. i'm running a tb stall and the best 60' is a 2.22. love the way this cam pulls up top, but would recommend at least a 3000 stall preferably a 3500.
