pickup tube oring?
pickup tube oring?
as most of you know, ive been having an oil pressure issue on my freshly rebuilt 6.0. so i took off the pan to look at the o ring. lowered it down and pulled the oring off and it was black. i thought it was supposed to be either red or blue? the engine is an 06 lq9. the oring looked fine, and i noticed that the pickup tube where the oring sits on it has a red strip going around, i guess to let you know that it is supposed to be a red oring. it wasnt pinched or anything, i just want to make sure whats supposed to be there before i put it back together. any help is greatly appreciated
When I took my LQ4 apart the O-ring I removed was red, the melling oil pump I purchased came with a black and a green. The black O-ring was too thin and the green matched the red o-ring so I used the green from melling nice tight fit I haven't fired it up yet but I'm sure its correct, hope this helps.
Formerly darynC-10/23/10
whenever you take the o ring out ,if its still in perfect conditon( no pinches).. dont throw it away, it regains its original shape within a day or so - ya never know, just incase your in a bind and cant find the right o ring
PT's Slowest Truck
Yep, a lot of guys have reported this issue when using a black or blue o-ring...can't really blame the builder as that's the part/part number that these oil pumps call for. Personally, I only know that the red o-ring is the one that works from people's troubles on this web site, as it isn't common knowledge. I wish that someone would let GM in on the big secret, so they can change their catalogs and delete the problem o-rings
I retraced my steps & looked by roadside. Akin to finding a feather on a stretch of road, near impossible. So I had to go order another, & they wouldn't do it w/o cash in hand. What a hassle.
It took 2 days to get replacement o-ring #2, adding more time to the job than already. Lesson learned: just cause u think u have somethin stuffed in your pocket, when u really need it under these conditions, it won't be there.
I think I kept my old one for those JIC instances.
So I picked up the red oring, big difference in thickness! Installed it, made sure everything was good,then I put oil in it ,unhooked the spark plugs and turn the engine over a couple of times. Still no pressure. Do you guys think I need to let it fire and run for a few seconds? I know that when you start a truck it takes a second or to before it comes up. Just wondering if turning it over without spark will build enough pressure or not
