pistion rings for boost
Don't use hellfire's or similar on something you want to last awhile, they have a lot more tension then average performance rings and will wear your cylinders relatively quick. Good for a drag car or true weekend cruiser only. Like others have said, even stockers do well, especially with a hair wider gap then stock. Total seal is what I'm running, seen them used quite a bit around here.
11 Second Truck Club
There is a theory among some very reputable engine builders that say if you leave the second ring gap a hair wider then the top, it promotes better ring seal by letting pressure escape between the two rings. It's been tested for years, and it's only a minimal gain (10hp max?) but has no adverse effects. Jarrett actually told me about this trick. There is some info about it here and there on tech also.
It also helps that my gaps are on the tighter side compared to others preference, but I'm also running e85 exclusively along with meth which cuts down on the heat seen by the rings, and 4032 low expansion pistons with the rings set down a touch farther which also helps them with the heat. Fwiw, .028 top, .026 is the spec used for a 4.000" bore by many builders, but they no doubt would rather be on the safe side for a customers build.
