Piston delete mod
Old 09-07-2021, 04:41 PM
  #51
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by DMarts10
How I cleaned out the intake…
soaked the inside with purple power then…
The Super Douche 3000!!! You should get a patent on that...
dantheman1540 (09-08-2021)
Old 09-24-2021, 12:26 PM
  #52
DMarts10's Avatar
So got the truck pretty dialed in on hptuners. I interfaced the wideband by using the egr sensor voltage pinout on the pcm, a little bit of a learning curve. Drove the truck for around 4 hours tuning the ve tables. Engine feels strong but started developing a tick (not knock) when hot. I went through the exhaust and think I took care of a leak under the trans pan. I have pacesetter long tubes into speed engineering dual 3s. I haven’t had a chance to take it back out on the road to see if the problem is solved yet. If it’s not a leak, I might be looking into replacing some lifters. Anyone have any tricks for spotting an exhaust leak? Truck is so loud that it’s impossible to audibly find a leak. Ill also copper spray the drivers exhaust gasket for good measure.
Aside from that, just got in some new Hoosier 295/50/16s and looking forward to making it to the strip before they close (end of October). Hoping to run 11.5s at 118ish
Old 09-24-2021, 01:04 PM
  #53
shakenfake's Avatar
Received 1,271 Likes on 970 Posts
Put a smoke machine on the end of your exhaust pipe and start it up. Smoke will come out somewhere.
Old 09-27-2021, 07:54 PM
  #54
DMarts10's Avatar
I just separated the bank 1 header, and there were visible exhaust leaks in all but one cylinder on that side. I had installed mahle mls manifold gaskets because the price was right and ratings were good on Amazon. I probably should’ve went with the gm gaskets. I cleaned it up with some lacquer thinner and hit it with copper gasket spray. If that doesn’t work, I’ll order some gm gaskets. At least I found the source of the “ticking”.
Old 01-03-2022, 12:02 PM
  #55
DMarts10's Avatar
Anyone know a trickto removing these stickers on my new tires?
Old 01-03-2022, 12:05 PM
  #56
shakenfake's Avatar
Burnout lol
The following 4 users liked this post by shakenfake:
dantheman1540 (01-03-2022), DMarts10 (01-03-2022), smokinlmm (01-04-2022), zz454Chevelle67 (01-04-2022)
Old 01-11-2022, 08:20 AM
  #57
Jonblarc7's Avatar
For exhaust leaks
Duck tape a shop vac to the tail pipe and seal it off. Turn the shop vac on in reverse so it's blowing air out instead of sucking it in.
Now while the exhaust is cold spray soapy water all over your exhaust. It will bubble where there are leak. If the exhaust is still hot it will just evaporate away. to fast. Work like a charm and is really easy.
arthursc2 (01-11-2022)
Old 01-11-2022, 11:39 AM
  #58
DMarts10's Avatar
Originally Posted by Jonblarc7
For exhaust leaks
I like that idea. Next time I have a leak I’ll give that a try. Ended up being the exhaust manifold gaskets. I ended up ditching the stock mls gaskets for some thick remflex gaskets. My pacesetters are just a little to warped for thin gaskets.
Jonblarc7 (01-11-2022)
Old 01-11-2022, 02:10 PM
  #59
Jonblarc7's Avatar
I used remflex on my L86 too. Once I get it back from the machine shop I'll use them again.
DMarts10 (01-11-2022)
norcalguy
01-05-2006 02:09 AM
Quick Reply: Piston delete mod
