piston install
#21
get in there and check your crank. make sure that the journal is clean and no nicks... make sure your cylinder wall is free of nicks from the piston... you may want to run one of them little honing ***** through it. make sure to gap your new rings to spec.. plastigauge your rod cap on your crank with ur new bearings. if all is well. tq er down and flush your engine.
next is making sure your blower is okay.
#25
I would say if you want to replace the one piston with an identical OEM one, then just leave it in. If you want to do all eight, it's better to pull it.
Mine ingested a valve. This was exactly what I saw after pulling the head. It was jammed partially through the piston.
lycominghunter
08-15-2015 12:26 PM
1987cut
07-12-2015 09:59 PM
