Piston Rings???
Perfect circle offers a low tension set CLE.315-0060 they run about 140.00. MAHLE has a set MAH.4005MS15 that are std tension and MAH.4005ML043 that are low tension. The mahles are file fit. I'm sure total seal has them also. My diamond pistons came with total seal rings that are 1.5 1.5 3.0 I think.
Custm2500's Rude Friend
This what your looking for??? They offer a 4.005 set which I believe should be what your looking for... Kyle should know If he is helping you with this.
http://cgi.ebay.com/ebaymotors/Mahle...QQcmdZViewItem
ok so rings need to be file fit, or "4.005" bore size". Also does it matter if they're high or low tension? I also found a set of perfect circle ones for 4.000" on Summit for about 100 bux I believe. That ebay listings is a great deal
Thanks 1fastbrick, u've been A LOT of help. All of you have.
lukn4trbl355
10-21-2015 11:19 PM
