piston rings, bolts and bearings
how do you think a set of et performance 5.3 stage3 heads will work on this motor?
Cylinder Head: LS1 Application: Street / Race
Port Volume: 230cc Chamber Volume: 64cc
Test Bore: 4.000" Test Pressure: 28.00" Water
Intake Valve: 2.055" Exhaust Valve: 1.570"
Valve Lift Intake Exhaust Valve Lift
.100" 82 58 .100"
.200" 162 115 .200"
.300" 210 154 .300"
.400" 265 187 .400"
.500" 297 209 .500"
.550" 310 214 .550"
.600" 320 222 .600"
.650" 329 227 .650"
Exhaust to Intake Flow Ratio 71%
.100" 82 58 .100"
.200" 162 115 .200"
.300" 210 154 .300"
.400" 265 187 .400"
.500" 297 209 .500"
.550" 310 214 .550"
.600" 320 222 .600"
.650" 329 227 .650"
Sounds like your making progress eric, but if you planning on removing the heads at a later time i would get ARP head bolts... I think i read that if you have head studs you can't remove the heads with the engine installed in the truck... But if you not going to remove the heads anytime in the near future then just get stock bolts... Also i was told that main bolts are reusable...
lycominghunter
08-15-2015 12:26 PM
Dezert1500
07-30-2015 02:51 PM
