which piston would you run?
Old 04-04-2011, 10:11 PM
11 Second Truck Club
fastrt's Avatar
Default which piston would you run?
I have a chance to get either a set of JE, Manley, or Diamond pistons for about the same price. All 3.905 bore flat top -2cc, 6.125 rod, 3.622 stroke. Which ones would you guys run and why?
thanks guys
Old 04-04-2011, 10:16 PM
HEADHUNTER92's Avatar
how thick are the rings and how far apart is the spacing between the rings.. try to keep them space apart as much as possible.
Old 04-04-2011, 10:23 PM
Swerve7rpm2000's Avatar
I have diamonds currently, all are great pistons imho, just seems like when you hear LS diamond pistons is always there too
Old 04-04-2011, 10:54 PM
offroadrider12's Avatar
I know my bikes always liked JE stuff. I think that's what most NASCAR teams use too. Probably couldnt go wrong with any of those brands. I'd base my choice based on what material each piston is made of and the thickness of each ring and how far apart the ring lands are as said above. If you want another one to look at look at CP pistons.
Old 04-05-2011, 12:22 AM
9 Second Truck Club
stock48's Avatar
I like the autotec, and Mahle's; you just have to keep on your tune up with them.
Old 04-05-2011, 01:02 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
I'll be looking at CP pistons when the time comes.
Old 04-05-2011, 02:10 AM
swift700's Avatar
x3 on the CP pistons. When i got them I was super impressed with the finish quality. The top land and unique underwebbing looks super strong. I have heard nothing bad about them. I'll be running them in a few weeks and have great faith that they won't be a weak link. They have been run in some serious builds over the years.
Old 04-05-2011, 02:47 AM
9 Second Truck Club
stock48's Avatar
I like the Cp's as well I just can't afford them. Do you have any pics?
Old 04-05-2011, 09:32 AM
fastnblu's Avatar
For years, I've always wanted some JE's, when I do a build. Largely that was w/. traditional SBC, but carries over to LS stuff as well. I always liked em cause they were lightweight & strong, but they're kinda too high of a C/R (I don't need 12:1-14:1+on pump gas) for most of what I want, therefore I'll probably run their SRP piston. It's still JE, just more wallet friendly, C/R is more along lines of what I'd want in a either a N/A or F/I build, but has less machining underneath.
But, outta the gate, Diamond has embraced LS engines. Them & Lunati were at the forefront of LS builds, altho I'd favor Lunati more for their rods & cranks, just dreamin tho. I like Manley more for rods, not pistons; seems like they'd build some burly pistons tho.
If I had to pick & I'm no builder, I just pay attn. It'd go like this in no order: CP, Diamond, SRP (JE). And I'd also look at Mahle; it's kinda cool Mahle offers a matched set w/. rings & pins. Actually, it'd probably be in that order.
See who makes a bulletproof forging in either 2618 or 4032 that fits your needs, altho I'm thinkin u wanna spray. So that'll dictate material choice too.
Old 04-05-2011, 09:34 AM
EVILGMC's Avatar
x4 on CP
Quick Reply: which piston would you run?
