which piston would you run?
Old 04-05-2011, 06:23 PM
  #21
11 Second Truck Club
fastrt's Avatar
Originally Posted by Matt@Texas-Speed
We offer the Wiseco shelf-stock pistons for $759.99 plus shipping, which includes the good ring set!
thats a little more than I have in my JE's with a set of very good rings
Old 04-05-2011, 09:51 PM
  #22
swift700's Avatar
Someone asked for pics of CP's. Here they are. They cost under $700 with rings and pins. 3.905" bore.
Sorry about the crappy pics.
Old 04-05-2011, 10:18 PM
  #23
fastrt's Avatar
you got a deal! I couldnt find the CP pistons for anywhere close to that. looks great! I just read up on your build too, I didnt finish, but it looks good. and that 5.3 block still looks thick around the cylinders!
Old 04-06-2011, 09:24 AM
  #24
FormerVendor
Sales2@Texas-speed's Avatar
Cool! Nothing wrong with that!
Where's the skirt coating? How about the positive displacement on the other side of the valve reliefs to make the quench more effective, as well as making a deeper relief without giving up alot of compression? How thick is that top ringland?
Old 04-06-2011, 10:10 AM
  #25
swift700's Avatar
There is no skirt coating. If you want this option then you'll need to look at a different brand. I prefer non-insulated (non-coated) pistons that transfer heat to the cylinders more effectively.
The pictures are of -18cc blower pistons. They are negative displacement flat tops, if you will. For more positive displacement on the flat side of the head the dish would be smaller but deeper. This creates a ramp for the flame front on the piston side. Sure, you lose some squish with the flat dish but it provides smoother flame travel, more even cylinder pressure and resistance to detonation.
I didn't measure the top land. It looked plenty thick vertically and there is a surprising amount of material horizontally for a dished piston design of that bore size. This allows good heat transfer and gives added strength to counter bending force around the circumference of the land. The exception is at the valve reliefs, which I see as a potential weak spot. We shall see.
Old 04-07-2011, 11:51 PM
  #26
9 Second Truck Club
stock48's Avatar
Looks like a nice set of pistons. 2618Alloy? What clearence are they calling for?
Old 04-08-2011, 08:36 AM
  #27
swift700's Avatar
Yes, 2618 alloy. The spec cylinder-to-wall clearance is .0035.
The finish quality is excellent on CP's. Here's a piston of similar design built by a large manufacturer. The valve relief is cut almost to the bottom of the top land. That's a big weak spot. Notice that burr? Poor quality control:
Old 04-13-2011, 01:15 PM
  #28
fastrt's Avatar
my pistons came in....
Old 04-13-2011, 01:58 PM
  #29
JFOLM's Avatar
Nice.
Old 04-13-2011, 04:34 PM
  #30
fastrt's Avatar
Originally Posted by JFOLM
Nice.
thanks! I am proud of them..... should run good with a set of callies or manley rods....
Quick Reply: which piston would you run?
